Make Offer - Many parts! new, used and a 75 part out, 77ish engine complete
Status
Not open for further replies.
I'm afraid my tempt would be more of an insult. Hopefully somebody shoots you a good offer! [emoji106]
??? little acetone the paint will come right off....
The 75 started and ran for a bit. Nice gauges, it's hard to find that center panel looking that good. and very nice hand controls. It has a 78 tank, looks clean inside. That's original paint.
34mm clip ons on the 75, nice alloy headlight brackets, drop bars on the 79.
View attachment 58462 View attachment 58463
View attachment 58464 View attachment 58465
View attachment 58466 View attachment 58468
View attachment 58469 View attachment 58470
View attachment 58471 View attachment 58472
Crap, didn't know that. How much for the rim shipped to 93306?
gggGary......how much for a set of header pipes? Also looking for a left side carb body for a bs34. Shipped to 16403.
headers from a special OK? might should have a spare carb body. throttle shaft, butterfly in it? I'll assume broken float tower.
gggGary....how much for a set of headers..and would you have a left side carb body (bs34)?? Shipped to 16404.
Yep....a special. Towers are fine....its the threaded cast piece that holds the throttle adjust screw that is broken off.
Sorry I bogart my early parts. a crappy front drum, linkage missing just brought $160 on fleece bay. Maybe you should try to find a honda 350 front wheel/drum.
headers pictured, bare lh carb body with throttle shaft & butterfly, how about $85 to your door?
cleaned up rear wheel a bit and installed new shoes. drum plate would still need good cleanup and lube before use.
drum sanded up nice after those pics good to use.
I understand thanks though. Is there a lot of modification needed to get the 350 front wheel/drum to fit?
inside rear wheel after a bit of clean up and new shoes.
led turnsignals sold.
cleaning up the "spare" engine.
Might be easier than an XS650 unit it has a threaded hole for a brake stay. A bit smaller, wouldn't do for racing LOL. they are 36 spoke, you could use the whole front wheel I guess. Not sure of axle diameter or length. I'll guess you have to make custom spacers.
Status
