1. Dismiss Notice
    Dismiss Notice
Master cylinder rebuild
Discussion in 'The Garage' started by Mchinn, Feb 11, 2020.
  1. Mchinn
    Mchinn XS650 Member
    I have a 1976 Yamaha XS 650. The master cylinder Rebuild kit get that I purchased from Mike’s XS is a rebuild kit for their aftermarket unit. I’m trying to find a rebuild kit for a stock master cylinder
    Jim likes this.
  2. Jim
    Just checked K&L's application chart and they only go back to 77. So.... not sure. Have you tried Ebay?
    Have you taken it apart yet? Oftentimes you can get away with just cleaning 'em up and reusing the old seals.
    What part of Mo. you from?
    lakeview likes this.
  3. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    Try Niche Cycle Supply.
    grizld1 likes this.
  4. Jim
    Just checked Partzilla. They have an OEM kit for.... are you sittin' down..... 77 bucks. :yikes:
    grizld1 and Mchinn like this.
  5. Mchinn
    Mchinn XS650 Member
    Yep I took it apart it was completely rusted I’m really not sure at this point if I’ll be able to clean it up and reuse it. Gonna have to check it out again when I get back home. Also I live at the lake of the Ozarks.
    gggGary and Jim like this.
  6. 5twins
    18,576
    9,095
    688
    If you're not doing a full 10 point resto then a slightly smaller MC than what came stock will work better. It will give better "feel" and modulation. Stock size was 16mm or 5/8". The 14mm size used on the '77 and later models would work well. If you end up needing to replace it, this is the route I would go.
    grizld1, gggGary and timbeck like this.
  7. Mchinn
    Mchinn XS650 Member
    Ok thanks
    gggGary likes this.
  8. Mchinn
    Mchinn XS650 Member
    well did a lot of search and was able to find a kit on eBay for $20. So we shall see LOL
    grizld1 and gggGary like this.
  9. Mchinn
    Mchinn XS650 Member
    I was able to find one through this company appreciate it
    Jim, grizld1 and gggGary like this.
  10. Bushyeyed1
    Bushyeyed1 Cafe Racer
    I have all my original front brake parts for my 80’ XS if your looking for a used part send me a PM and I’ll see if I can work something out with you.
    Jim and grizld1 like this.
  11. grizld1
    grizld1 Grumpy old man Top Contributor
    While you're working on the brakes, bear in mind that recommended service life for rubber brake lines is 4 years.
    Jim likes this.
  12. David Toll
    David Toll Reliving my youth?
    After advice on this Forum, I installed the braided lines from Banggood. They seem OK and they are cheap enough to buy a couple. Only problem was that they had to have a slight twist in them to face up to the cylinder/calliper inlets - no swivelling ends, least not on the version I got. They did have them but had sold out by the time I ordered.
    Jim and gggGary like this.
Share This Page
