blow up of an early master cylinder with lever parts.
This is a 72-73 M/C with the brake light switch held on by the lever bolt.
A cotter pin at end of lever bolt is not shown.
To remove the lever from the housing; the brass bushing is threaded onto the bolt, the steel sleeve is a slip fit, remove the cotter and nut, pry the brake switch off the retaining pins. Using aluminum or brass to protect the threads, tap the bolt and brass bushing together up out of the housing to free the lever.
72-73 Internals in assembly order
AFAIK there are no overhaul kits available for this MC
Ebay and mikesXS have new replacements for the 74-76 but they do not have provisions for the 72-3 brake light switch.
