1+ on the K&L.K & L
1+ on the K&L.K & L
Find some VHT caliper paint. Advance Auto Parts sells it here. You should be able to find it there as well. Did both masters and wheel cylinders, spilled brake fluid on 'em... no affect. Great stuff. Once I found the VHT stuff, I threw all my Duplicolor cans in the bin.Also pretty pissed the rattlecan DupliColor engine enamel isn’t as stout around parts cleaner as I remember, let alone brake fluid. Maybe it didn’t cure properly in the cold?
Absolutely.The Standard master cylinder rebuilt is a great master cylinder to pump dual calipers with
Jim gonna +1 on double disc as well ? Lol
A somewhat funny story about the wheels taking a second disk.Here's my resto thread. The brake mod is about a hundred pages in. Stock wheel takes 2 discs just fine.
Yes, XS750/850 are 7mm disc equipped and are the quickest and easiest left side add on. Remember, the SR500 left side brake is a 5mm thick disc and the Caliper hanger is cast narrower than the XS components for that 5mm disc.XS750 XS850 STANDARDS only, the specials are different.
