jtoolin73
To Tool or Not To Tool?
Hope every one is healthy out there.
So I was quite sure that I had these holes marked on center, where they needed to be drilled...
As you can see my measuring or drilling skills are lacking and my four holes are off by about 1/4 in.
These are/were pilot holes just to get an idea of gas tank position.
My dilemma here is that I need to drill even larger holes, 5/8" diameter in order to fit the bungs that need to be welded in there.
I can either line up the front holes and drill the back or vise versa. regardless the holes are off center of the drill and I don't know how i'm supposed to make a proper/centered hole, at the correct placement.
I did buy a drill guide block that I was sure was going to be my fix but it's too long to fit anywhere on the frame at the hole i need...
Hopefully the pics will help my lacking description...
Any good ideas on how to drill a proper hole???
