very low, 300 ishThat's pretty much normal. How many miles on that oil?
Ya! What they said. You should expect that every oil change. You just don't want to find pieces you can read part numbers on.
Hope that's not Madness or I'll fell bad.
Speaking of that starter gear...I have replaced the gear with a mikes one, also used an NOS spring clip per the forum, moved the clip to the correct notch in the cas and tested the pull with a scale and got 7lbs but am still having bad grinding during and for a few seconds after I push the electric start. Is there something else I should be looking at....Yes, what you've found is typical and normal. As your pic also shows, you'll often find a few little black bits and/or a few small metal chips. This is an old engine design and a bit crude inside. The best way I'd describe it is it runs a bit "dirty". The little black bits are rubber and my theory is they come from the rubber damper ring attached to the #4 starter gear. This ring gets old, hard, and begins breaking down. Here's a particularly bad one .....
