pamcopete
Ride.Enjoy.Life is Simple
bobber bill,
Here is a pic of the installed carb on the left side:
As you can see, the carb ends up horizontal if you install the rubber carb holders correctly. The vacuum barbs are as shown.
It is not advisable to not use the aluminum manifold extensions. They are an important part of the whole reason to install these carbs.
I am not familiar with the throttle you are using, but I could suggest that that is the reason you are having difficulty getting the slides to drop. Try disconnecting the throttle cable from the throttle to help determine if it is the throttle cable or the throttle.
If the throttle cables are too long, try routing them on the left side to use up some of the length.
