Tz250racer
- Messages
- 103
- Reaction score
- 0
- Points
- 16
I don't know if backfire is the term but propably popping is.This "popping" was not there with the stock carbs.
bobber33,
Try connecting the vacuum barbs together.
Tz250,
When installing the carbs, put a little oil on the gasket surfaces to ensure an air tight seal.
Try this sync method:
1. Make sure there is slack in the throttle cables.
1a. Adjust the air screws 1 1/2 turns out
2. Start engine and allow to warm up.
3. Pull the vacuum barb plug off of one of the cylinders.
4. Adjust the other cylinder idle to 1,000 RPM
5. Replace the barb plug.
6. Pull the barb plug from the other cylinder.
7. Adjust the running cylinder for 1,000 RPM.
8. Replace the vacuum barb.
If you have true dual exhausts, then you can "tweek" the idle sdjustments so that the cylinders sound the same.
With the engine not running, do the following:
1. Remove the air filters.
2. Turn the throttle grip to obtain a full up position for one of the carb slides.
3. Adjust the other carb slide cable to obtain the identical up position of its slide.
