1. Dismiss Notice
    Dismiss Notice
Mikuni TM34 German Topham Setup
Discussion in 'The Garage' started by Moonmanzn, Jan 9, 2017.
  1. joestella28
    joestella28 XS650 Member
    19
    0
    1
    UK
    Slightly off topic, did you have the wide yokes made or are they off another bike? (Maybe one of the Suzuki cruisers?).
    I need a set making for my street tracker but I'm not sure where is best to go in the UK?
    Thanks,
    Joe
  2. fredintoon
    fredintoon Fred Hill, S'toon.
    Hi Moonman,
    yeah, I remember English summers, it only rains on weekends and Bank Holidays.
    But no, not the brake rod from the wheel to the pivot arm, the long rod from the bottom of the pivot arm to the forward control brake pedal;
    Surely that long skinny rod pushes, not pulls?
  3. Moonmanzn
    Moonmanzn XS650 Enthusiast
    I dont know if you are joking or not, seat setup was just where I felt comfortable sitting, Controls are staying but im moving to drag bars as they feel even better. Im not a bike designer or understand power to weight ratio/location...just welded it up as it felt good, please point out any life endangering errors I might have made :)
  4. Moonmanzn
    I dont know what they are off unfortunately ( Loads of mismatched thing i recieved on bike ) All i got told was they are wideglide?? They are solid though and well made.
  5. Moonmanzn
    Ah yes sorry, I misunderstood...but that rod isnt skinny its actually quite thick and has the threaded ends with locknut to lengthen or shorten it. I see what you mean and went and had a look at it, if you saw it in person I think you would think it was actually ok and it doesnt flex at all.
  6. Moonmanzn
    Onto the carbs....TM34 setup arrived, was a tight fit but Its an absolutely lovely bit of kit.
    Put them on and filled the bowls and off she went, question ( and I new to all of this ) I had 32mm PWK from Mikes Xs, it sounded ok....with these on the bike sounds like a race car....it idles much louder and crisper and when I rev it, muuucchhh louder?? More fuel and bigger airway 32mm vs 34mm ??
  7. fredintoon
    Hi Moonman,
    was Scott joking?
    Depends if you regard the bike's ability to do easy wheelies as a glitch or a feature, eh?
    But I gotta advise you not to ride that bike before you've installed a rear mudguard.
    The feet-forward riding position puts you at risk of bouncing off the seat if the bike hits a large
    bump or pothole and if your arse lands on the rear tyre instead of a rear mudguard the tyre
    will rip your nuts off.
  8. grizld1
    grizld1 Grumpy old man
    Less fuel, Moonman, not more; remember what I told you about those Pukes? The needle jets are too fat and there's no way to change that. In spite of the accelerator pump, you'll see fuel consumption go down with the TM34's because they can be properly tuned. And I'll say it again: there is no such thing as a PWK32 and there never has been. Those are PWK28's bored out to 32 mm.
  9. CoconutPete
    CoconutPete 79' Special & 78' Standard
    OH GOD THE VISUAL I JUST GOT!!!!!
  10. littlebill31
    littlebill31 Smells of Raw Fuel
    It's no joke either. Almost happened to me when my carb backfired. Engine died and then fired back. I got thrown back a bit and slammed my ass on the fender.
  11. littlebill31
    weekendrider likes this.
  12. Jack
    Jack XS650 Junkie
    The RS produce higher velocities through the venturi effecting how the intake responds back to the vacuum pull on the jets . They're just a far superior set up. D porting the intake's will give identical results
  13. Moonmanzn
    Thanks guys...grizld is correct less fuel...but im trying to figure out how to tune these...pump needles jets etc...now i have a smoky bike when i rev it...didnt happen on the old carbs...only diff is when i installed these the acc stuck for 2 secs and revs jumped but not massively...thinking maybe rich mix is washing fuel of walls and blowing it out...its done 10miles since rebuild so im hoping rings valves etc are not leaking oil??
  14. grizld1
    To resolve your issues, do six things. 1. Check oil for elevated level and/or smell of fuel. 2. Remove the carbs and stop riding the motorcycle. 3. Buy a manual from Topham for the TM pumpers, or the Sudco Mikuni Tuning Manual. 4. Check mixture screw position and post it. 5. Inspect float level. 6. Strip the carbs and post a complete jet list (don't do this before you have a manual in hand).
Share This Page
