No great shakes, just a wake up. Trying real hard to do everything in order.
It had 165 145 compression cold and not oiled.
Had to replace shift shaft, stripped splines. So side covers got cleaned, buffed a bit, new front sprocket, clutch pushrod seal. Rotor and brushes tested good. Oil and filters changed. Head retorque done, cam chain and valves set. cylinders got carb cleaner, then PB blaster, valve seals got PB blaster, lots of plugs out, kicking. After replacing the roached fuse box, TCI ignition makes sparks, YEAH!, Fired and ran a few seconds off a bit of carb cleaner. Carbs up next.
Slowly dragging in lots of parts from the shed to make it complete enough to test ride.
