Floats were
seriously bound (varnish) to the pivot shafts.
View attachment 129877 View attachment 129878
Next time I will use a heat gun to loosen the varnish before driving out a set that is this stuck. Got a bit smarter on the second pin used some solvent and DUH, went back and forth a bit, that really eased the extraction. Note; the shaft and shaft towers are handed, the head always goes to the right as viewed from back, bottom of carb. I use a close fit # drill bit and solvent to clean the inside of the float bushes, assemble with TDS.
