dfphoto
Hi group for a long time I've thought about what to do on my RD250, decided to do the Minton Mod and after the ordeal of removing the lower bolt (tip: I used a 12 volt impact gun and it was easy). I bought a little Harbor freight drill press - like device for my battery drill.. I took the forks apart and the damper rod requires a circlip removal which was no problem then some parts came out but the odd thing is at the end of the actual damper rod there is a sleeve (bullet shaped) and that piece slid off the actual damper rod, then I was able to slide the assembly out the top of the tube.
I then proceeded to drill 2 new holes at the bottom of my damper rod and enlarge all 4 to 1/4" then enlarged the 2 upper holes and then wire brushed the holes to smooth.
My problem is on the 2nd fork the bullet shaped sleeve on the damper will not come off, I'm a little confused as I took another 3rd fork tube apart and it also will not come off (bullet sleeve on the damper rod). I'm not sure if the 1st one was a mistake that it came off but I don't see anyway it should stay on. None of my manuals or parts manuals show the damper rod has an extra piece on the end yet I have one in my hand... Really could use some help on A. is that sleeve suppose to come off B. if it stays, how am I suppose to remove the little parts on the damper and get the damper out of the upper fork tube!
I have a pic here...A. the bullet shaped image is the damper rod the end is where the bolt goes through the bottom of the fork through the sleeve and threads into the damper rod. B. is a pic. of the parts that go on the rod after the sleeve if you're look up the fork tube from the very bottom.
