Your oil seal is marked E 35 SO 7 13 4 HS - does that mean the seal is 7x13x4 mm for inner, outer, thickness?
I believe that’s correct. If I’m wrong , maybe someone else will chime in here.
Yes, that size is correct. Here's a list I made up. Sizes are in MM and shown as I.D.- O.D.- thickness .....
Here's a couple more you might like.
Oil seal 9310407036 now received. Hopefully fits tacho drive. Still waiting for ten viton O-rings then do oil change and take a look at the oil leak.
Meantime:
Well?
Hmmm....she looks rather sad that way - but if it keep the slippery stuff inside then, all-good.
Result! Will have to see how long the cure lasts . .
Today, at last, able to take the diva for a test run. On basis of a run to Galashiels, leak at tacho seems to have gone:
Result! Will have to see how long the cure lasts . . .
Gratuitous photo in her full glory:
