Atoyot
G'Day all,
I've been reading a lot of the great material on this forum for a while now, but this is my first post. I hope I'll be forgiven for this first one being a quesiton, but I just need some help to get started.
I've got an XS650C that I've hardly had to touch since buying it some time ago, as I've mainly ridden it around town at low speeds, but recently, on a trip out of town, I found that on a steady throttle at 40 - 60mph (and faster), it misses and stutters badly. It accelerates nicely with no problems, idles beautifully, and does everything as it should other than missing on a steady throttle. Using full choke at speed seems to stop the missing, so it's telling me that it's running lean on 1/4 to 1/2 throttle, so the first thing I should check is the needle?
The bike is standard, and apart from this issue, it starts easilly, warms up well and otherwise runs great. My mechanic hasn't looked at it, and won't until I've upgraded the ignition and charging system, but I think that this problem is with the carbs, as using the choke seems to fix, or more accurately, mask the issue.
I haven't checked anything yet, but am I on the right track to start troubleshooting this issue? I think I'm on top of all things to check, but is that the most likely place to start?
regards
Andrew
regards
Andrew
