Kickflippin
The microfiche was a little unclear on whether the chain-side collar attaches to the dust boot, or is a free floating piece. if it is i have no idea how it fits because it is all SNUG.
I've adjusted and reset chain tension and alignment multiple times now, but after each ride the spacer/dust cover is askew and the wheel is slightly off alignment, even though the Axle hasn't moved and the alignment marks are still true.
Axle came with the bike with two spacers on either side; the larger dust boot deal on the chain side and a smaller spacer against the disc. Wheel has new bearings, seals and the internal spacer is intact, though it was loose on assembly. Thoughts? Thanks.
Underside
disc side. Seems solid over here:
Underside
