xs650newb
Hello everyone,
As I said in a previous post I have had trouble getting my 1981 XS650 Special running. It will idle ok, however, when I give it throttle it sputters and dies.
I have
1) Adjusted cam chain
2) Adjusted valvles
3) Cleaned carburetor (multiple times)
I am running a 45 pilot and 135 main jet, with a heiden tuning kit needle in position 3, and the mixture screws backed out 3 turns. The richer profile is because I am running drag pipes (with internal baffles) and mikes performance pod filters.
When left to idle for a while the plugs appear white. I tested for air leaks and that atleast one of my throttle shaft seals is leaking.
In the course of replacing the throttle shaft screws I noticed that the o-ring for the mixture screw was destroyed. I have ordered new ones from MikesXS (along with Canadian needles and needle jets).
QUESTION #1
When I installed the old mixture screws there was quite a bit of resistance. It appears that the o-ring was slightly bigger than the hole and I had to force it to go in. I am pretty sure this is what destroyed it. Is this normal? Once I pushed down deep enough, where the screw first became threaded the resistance went away and I didn't meet resistance again until the screw was bottomed.
Question #2
Since my plugs are so white I am afraid of more air leaks. I can't check right now, but I also suspect my intake boots. They have a metal guard around them. Do I boot a clamp around the metal guard? How tight should the clamp be?
Thanks,
Adam
I have
2) Adjusted valvles
QUESTION #1
Question #2
Thanks,
Adam
