ejdirin
I'm not sure if anybody has tried this, but I'm interested in making an air intake manifold that uses a single air filter located off to the side of the bike. My idea was using some sort of pipe (copper was my initial thought because its lightweight and easy to work with, but I found out it gets pretty expensive once you go above 1.5" ID) and 2 couplers (a 90 degree elbow and T-coupler) to bring the intake to the side of the bike. Pretty simple in theory...connect the 90 deg elbow to one carb, the T to the other, connect them with a tiny length of pipe and use another small length to bring it out to the side.
My questions are 1) Has anybody tried this? 2) Is this going to work? My thought is that the amount of air the filter is exposed to on the side of the bike will make up for the decrease in filter number. But I know things aren't that simple with carbs....
I've seen some guys selling a manifold on eBay that'll convert the 650 into a single carb system, but I'm just interested in moving the filter.
Any thoughts/ideas/pictures? Thanks!
