YIKES!!!!! Mick.........remind me IF I ever get to your side of the world to NOT pitch a tent near any trees!!!!! I'm sure it's happened here in the States but I've never heard of it.
Yes sir......that's a bowline knot at the end of my guy lines......and I just run the loose end through it in a "sorta" truckers knot.
Okay......where was I????
The tarp is 12'x16' and we now have it staked down with short guy lines along the 12' end.
Measure back 6' and this is where you'll have your ridge poles. Most of the cheapo tarps have a grommet at this point. Go ahead and set a stake at either side of the tarp in line with the ridge pole.....approx 5' out. That way when you set the pole you can go ahead and run the guy.
Next you'll want to stand the ridge poles and loosely guy them off.....don't forget the ridge line we already talked about.
Remember the order.....ridge line, tarp then the guy over the tarp. If you put the guy under the tarp, there's nothing holding the tarp onto the end of the pole and it can come off.
Now you add the front poles and pull the guy at an angle that apposes the rear guy.
All of this is a bit shaky when your doing it by yourself but it will come together as you go around and tighten the guys and straighten the poles. IF the wind is blowing hard....you'll need an extra hand. If it's blowing hard enough...you might as well just lay the tarp out and crawl under it.
You can go back and redo the front guys and double them up for better stability.
Now you have a 12x10 covered area and a 12x6 area for your tent. BUT you have all this flat tarp that WILL catch rain and you need to shed that off so..................
You add a center pole. I use a can that has a dimple in the bottom (hammer and a drift)
But a bottle works just as good......as long as it doesn't break
Here it is being used at the wonderful TWOs ( we are SO lucky to have some of the best motorcycle campgrounds so close to us) I apologize again for the bike not being an XS650......but I'm working on that.
OH.......and that's my 30+ year old tent under there.
next up......the air bed......to be continued.
