Btw, how the heck does OldSchoolCarbs get those carbs to look like that? Jeeze, they look like motorcycle jewelry!
Info on the cam chain adjuster assemblies, see posts 22 and 23 here .....
http://www.xs650.com/threads/cam-chain-tensioners.1056/page-2
Pete, '76 would have been the 1st year for the type D assembly. It was implemented by Yamaha along with the 1st linked carb set. The previous type C adjuster was too large and would have interfered with mounting the new carb "bank".
So you think I may have the wrong needles in my carbs? If I pull those out and they have rubber tips, they are the wrong needles?One thing I noticed in your carb pic is the float needles with the little retaining wire on them. Stock ones weren't like that. That was a BS34 viton tipped needle thing. So, your float needles are most likely replacements, and maybe not correctly fitting ones at that. Supposedly there are some viton rubber tipped needles out there that you can swap into the BS38s but I've never tried them.
Yes, it will, but there's no need to go through all that. All you need to do is swap the plungers and add the lock nut. All the other parts are the same on the type D and E assemblies (housing, spring, acorn cover nut, adjusting screw). To change the type D to a type E, all Yamaha did was install a longer plunger. The longer plunger lets the adjusting screw stick out the back of the housing more and that provides the extra needed room on the screw for the lock nut.
But you say you have a lock nut already. If so, then maybe someone updated your assembly already. Got a pic of it? You should probably check your plunger too. To do the upgrade, you need to add the lock nut AND change the plunger. Many changes have been made to these bikes over the years by P.O.s and not always correctly.
