Also - can you get both of the clutch actuator rods out from the left side - or do you have push one out from the right?
Amen to that 5T. I got lucky with the Mikesxs long rod, but there quality is so random. I always look for OEM parts these days.Yes, I suppose it's possible my long rod wasn't hardened properly but I'm sure it wasn't the first and probably won't be the last. I'll never buy another clutch pushrod from Mike's, long or short. Especially now that I know originals can be had for the same or less.
No, you have to take the front sprocket off so you will have working clearance to change the bushing and seal. Gives you a good opportunity to re-install with the correct torque.Yes I'm planning on switching to a long rod.
Can you help me with the correct search wording on eBay? I want to make sure I order the right part.
Also I want to be clear. The long rod replaces how many pieces exactly? My understanding is it is two rods with a ball bearing between them. Is that correct?
I will also replace the bushing and give the worm drive a good cleaning and look over and lube before re assembly.
I was going to try and change the seal without removing the front sprocket. Then after getting it running for a while, check to see what else might be drooling under that cover.
There are so many potential places for oil to leak from in there.
Nothing wrong with a little humour in our postings!....and there's nothing sadder than a long rod that has not been properly hardened.....
<sorry - simply couldn't resist>
