and no oil leaks
four hours is some road test, It must have made all the problems you've had just fade away .
How did you find the vibration ...was it a big issue?
funny You mentioned that.
The head had started leaking a bit.
I smacked myself on the head because I hadn't torqued the head bolts.
I tightened most every bolt n nut on this girl. But noooooooooooo I just to good to check the head bolts.
So the day I painted the head, after cleaning the engine I torqued the head bolts.
And while riding I checked for oil, no oil. When I got home I checked for oil, no oil.
even when I had changed the oil this engine had leaked oil from the oil drain plugs.
I used permatex aircraft gasket sealer #3 on them and they aren't leaking anymore.
If the engine is leaking oil it is from under the left side cover. I have those seals except the crank seal. I am a happy camper.
The vibration is no bother. The only thing I wish I had used my Go Cruse throttle control. That is the best mod for my right hand. I'm right handed and right hand go numb easy. throttle control lets me shake it out.
But when I use the throttle control may hand does not go numb at all.
Yes it was a great time very relaxing Sir
