No. Steel doesn't become malleable until well past the point where you'll discolor the chrome.Also, should I apply heat? Most youtube videos i see use heat (they are on car/truck tires though)
If it's got a ratty old weather checked tire like this one does, have 'im dismount it.... prolly save at least 20 bucks in shipping.Working with the seller now. He might have one he can exchange.
He actually has a buddy that drives to st louis monthly. Might make the exhanche through him.If it's got a ratty old weather checked tire like this one does, have 'im dismount it.... prolly save at least 20 bucks in shipping.
I requested him to keep it on. Since I'm still working on it I wanted to be able to roll it around. Tires were gonna be my last purchase before I got it licensed and registered.Never cold figure why a seller would sell them with a shitty tyre left on!!!!.............just laziness i guess, .................like a bike seller who doesn't wash the bike before taking the pics that get put up for sale!!!!
Yep iv used the side grinder approach to cut off semi tires on old semi wheels I referbeb for my old job.I just cut across, side to side using a grinder and tin snips for the last bit ............2 places if i have to...........after i break the bead
Get yourself some quality tire irons and you won't be needing to cut anything, lol. These are the best I've found .....
https://www.kentool.com/
Yeah. I'll need to get some tire irons to put new tires on anyway. But for not I'm not touching this tire while I wait for the seller to potentially trade me a better one.No disrespect 5T, but I can't see the sense in struggling to take off an old hard tyre with tyre irons when a grinder will do the job in 1/10th of the time with no effort. Time saved with the grinder means the new tyre is on and your away........
Means either your float valve or it's oring is stuck/bad... or your float filled with gas and sunk. Out of curiosity, can you pull the plug on that cylinder, shine a light down there and see if it got wet from gas? Did the gas run down into the cylinder as well as out the airbox?Fuel started coming out of one of the air boxes. That means I need to adjust the floats in the carbs?
I did a full rebuild of the carb. Including replacing the valve with a new one. Hopefully it isnt bad. I can pull a plug here in a bit. I also checked my floats to see if they leaked before putting them back it. I kept them in a bowl of water for a week and they stayed afloat.Means either your float valve or it's oring is stuck/bad... or your float filled with gas and sunk. Out of curiosity, can you pull the plug on that cylinder, shine a light down there and see if it got wet from gas? Did the gas run down into the cylinder as well as out the airbox?
Including the o-ring?I did a full rebuild of the carb. Including replacing the valve with a new one.
That's not a good test. A hole floating above the water will never get wet. Here's the @gggGary method. Immerse the float completely (hold 'em with needle nose) in water that was bought to a boil first and look for bubbles. The heat causes the air inside the float to expand. It will force it's way out under pressure.... bubbles.I also checked my floats to see if they leaked before putting them back it. I kept them in a bowl of water for a week and they stayed afloat.
I do believe the oring is included in this kit. https://www.cruzinimage.net/2017/07/26/80-81-yamaha-xs650-carb-repair-kits/. Thats what I used. It would be in the brass fitting that the float valve goes into correct?Including the o-ring?
Yup.It would be in the brass fitting that the float valve goes into correct?
