Keep the thread locker, take the rest back. The only sealer you need is Yamabond or Hondabond, same stuff different label. Mike's sells the Threebond 1109 I think it is. Again the same stuff just a different label.
The rings, put the oil rin on first and set the end gaps 120 degrees apart. the middle ring goes next, set 120 from the top gap in the oil ring, the top ring 120 from the middle ring.
Put the snap ring for the piston pin in the pin hole to the inside of engine on both pistons.
A good coat of oil or assembly lube on the piston and cylinder, Slide the piston into the cylinder from the bottom. Keeping the pin clip on the inside. Work the rings into the cylinder with your fingers or a corner of your credit card.
Slide the piston in just far enough to cover the rings. Once you get the pistons in just that far, put your base gasket on the engine, roll the engine up so the studs stick out to one side.Slide the jugs down on the studs, keeping the cam chain and guides out of the way, Slide the jugs on far enough the you can slide the rods into the pistons. Once the rod holes line up with the pins hole slide the pins into the pistons and rods, instal the pin clips into the holes.
Once you have the pins and clips in place slide the jugs all the way on. roll the engine upright to install the head,cam an rocker cover.
Retiredgentleman has pics of how to do this. Not as hard as it sounds.
