My Traker
Paul Carr
Alliston , Ontario CDA
I hope I attached the pictures ok
This is my new toy, gas ,oil , decals and a few odds and sods before I fire it up
Cheers
Paul
Sweeet! If she runs and rides as good as she looks, you got a Super ride there!
YES!! Another tracker . Nice detail with the disc centres matching the tank. Must pull finger out and finish mine.
Sorry I am a lousy typist but here is the build
Chasis is a 1974 ,all lugs and brackets ground off and brackets welded on for the rear dic master cyl
Front forks from a 1978 with dual disc
Rear swing arm from an 81 special
Motor is a 74 with a 750 kit and 34mm roundslide Mikunid
Wheels 18 inch front and back
Glass Omars as is the Miler exhaust and fork brace
Think thats it
Also have a mint stock 1977
Should run it this weekend
Next build is a cafe racer if I can find another XS they are not too easy to get here
Cheers and thanks for the nice comments
Paul
Thanks Pregrid
I followed your build very closely and learned alot
Cheers
paul
i'm flattered. glad my trials and tribulations could be of some help.
I hemmed and hawed about the headlight like you've used versus the number plate I used. I like the look of your setup. what headlamp/brackets did you use?
I did the same humming and hawing over the headlight vs plate..... finally thought the number plate looked too much like a racer for me
Headlight is Genuine replacement fro XS 650 Direct
Your build looks perfect I have some stuff I did well and some I would like to do again
regards
paul
