moebius
Hey guys, pretty new to the forum and new to working on bikes but I was wondering if I could get some help narrowing down an air leak.
I have a 1978 xs650, started riding it this summer and I've had some backfiring popping issues for awhile now, only on the left side. I checked the points then adjusted the timing, after that I ended up pulling the carbs off and rebuilding each with gaskets, pilot jets, main jets (both stock sizes) and mixture screws. Also cleaned with carb cleaner and compressed air but the float bowls didn't look too bad. The air box was fucked so I decided to just put pod filters on it.
After that I realized the left carb holder rubber was starting to crumble so I figured that was the issue, ordered new carb holders from MikesXS, but only replaced the left one as the vacuum nipple on the right was running into the valve cover bolt and wouldn't fit.
Anyway long story short that didn't fix the leak, I can spray starter fluid right underneath the left carb holder and the idle goes up. So it seems like the carb holder is still the issue. I tightened the carb holder clamp as much as it can go without completely stripping the screw, made sure I pushed the carb in as far as it can go.
My next step is to get gaskets for the carb holders because they never had any, but I'm not really sure how to narrow this down. Some one said to cover the holder with grease to see if that fixes it temporarily to narrow down the leak.
Anyway I read this thread: http://www.xs650.com/threads/very-persistent-air-leak.3005/ and a couple others but I feel a little lost at the moment. Thanks in advance for any tips!!
Oh and here's the bike:
http://res.cloudinary.com/moebius/image/upload/v1503972001/IMG_3155.JPG.jpg
