blackbetty
XS650 Junkie
- Messages
- 786
- Reaction score
- 12
- Points
- 18
Sorry for being wordy....
I've read through the detailed carb guide and am just wanting the carb pros to review my plan of action, make any suggestions if you have any.
Here's the details:
76-77 BS38's
Uni pods
Straight pipes
Carbs are completely rebuilt with new diaphragms
Valves are set, .004 exhaust, .002 intake
Timing is set (Boyer ignition)
Timing chain adjusted
Rejetted to:
125 main jet
27.5 pilot jet
Dropped needle 1 slot
Mix screws a little over 1.5 turns out.
I have not synched the carbs yet (anyone know where to get m6x1.00 threaded nipples for my carb set?)
Was planning on using dead cylinder method to adjust mix screws and to synch since I don't have threaded nipples to use in the vacuum ports for my carb set just yet.
Right off idle it stumbles badly; gently rolling the throttle helps reduce the break up.
Right cylinder is popping occasionally out the exhaust at idle. It's honestly a little disconcerting, but this seemed to go away as the motor got warm.
Other than that, it starts and idles very nicely.
Since I haven't ridden the bike, I can't do plug chops, but after idling for a few minutes, they are blackish. I do know there is a small valve seal leak on the right cylinder, but the motor doesn't smoke and the exhaust doesn't smell rich Regardless, the carbs in this state make the bike unrideable anyway...
My plan of action is to first make sure the syching is on (I did not play with the synch screw during the rebuild, and the carbs were tuned when I bought the bike). I plan on syching using dead cylinder method, unless I can figure out where to get some threaded nipples for a manometer.
Second job is to bring the mix screws back to 1.5 turns out and use dead cylinder method to tune these.
After this, the carb guide suggests using a smaller pilot, but I only went from the factory 25 to a 27.5 with open pipes and pods, so I'm assuming my worries are mix related.
What could be causing the intermittent pops on the right cylinder? The pipe on the right cylinder is slightly longer than the left, would baffling help reduce this?
Any suggestions are appreciated; I also have a short video of the bike running if necessary.
Here's the details:
76-77 BS38's
Uni pods
Straight pipes
Rejetted to:
125 main jet
27.5 pilot jet
