yamamunn
Ok, got an 81 650 that sat for a few years ran when put away. Cleaned and sealed the gas tank, cleaned carbs twice after reading about fuel screw which I removed and recleaned. I did completely take it apart including spring washer and o-ring. Only fired on 1 cylinder ggggary recommended new plug caps this worked,thanks. Bike idles great but won’t throttle up as soon as throttle is turned it starts to blubber.started testing as per Clymers book almost every test failed ohm readings. Reg/rec, rotor,stator how can this be possible? Thought my meter was bad ( harbor freight ) so I bought a good one Fluke pretty much same results. Someone suggested weak magnet in rotor but it will hold an 8/10 MM wrench. Is there a test for the TCI and a way to test the stator coil pick-up?
