1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
New 75 no spark
Discussion in 'The Garage' started by sweatybetty89, Sep 23, 2021.
  1. sweatybetty89
    sweatybetty89 XS650 Addict
    Been looking around on the forum for a answer to this question not getting any where. Buddy picked up a 75 that has a blue xs charge e advance on it. When we bought the bike it started and would go but would get super hot and then shut off like a electrical problem just real quick like. He rode it a couple times (against my advice) and he made it out to the shop. Well he left the key on .... smh. The coil was fried. had no spark. Got new coil no spark. traced the wires got power to the red wire coming of e advance but not green is this right? My ground is good on new coil. It has a pma on it and bare bones wiring system. Did it fry the xs charge? I know they are kinda hated here. I'm running a Boyer on my bike and did that because horrible rep mikes shit has had on this forum. The green wire was also kinda shredded by the coil like it was looking for a ground and around the connecting bolts for the coil was covered in black plastic that looked like it oozed off the coil. Any help would be nice.
  2. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    You say the 75 is running a PMA. Is it also running a battery? If not, then try temporarily wiring a known good battery to the system. It needs good strong voltage to run. The PMA and capacitor alone may not be providing enough. I’ve never ran a PMA but have read on lots of similar issues here about this.
  3. sweatybetty89
    It is running a battery and very well could be low on charge where he left the key on
  4. willis
    Get a full charge on the battery and see what happens. If nothing there, start looking to see where the smoke got out. Melted plastic is never a good sign. Others here are way more knowledgeable in this area than I am. Hopefully they will chime in too.
  5. Xs650911
    Xs650911 Banned
    57
    21
    8
    Chicago
    My cousin had the same thing happen on his xs with the xs charge system. He traced it back to the coil. Replaced it and sorted out his wiring and it worked after that.
    sweatybetty89 likes this.
  6. sweatybetty89
    I replaced the coil. When I turn the motor over I'm not getting any indication on my test light from my field wire or pulse wire if you will. It's green. I bought new ignition. I had power every where but there. Pma is good ,battery is good, wires look clean besides that green wire coming out the e advance it smoked and had no spark after that
  7. sweatybetty89
    I'll let you guys know if the new ignition works
  8. sweatybetty89
    So got my motor all buttoned up and ready to put back in the frame. Sorry it has been a while since last post life and shit. Ya know? Well I got the bb magnet system mounted in my cam. I'm just wondering how I hook up this coil I've read a few things and am just wondering where wore that are coming from the stator plate. There are 5 wires on the box and 2 coming from the magnet pick up that replaced my braker points. So red goes to positive on coil spliced in with hot red/white from o.g harness. Black goes to negative and white is my ground. The other 2 are black/yellow and something else(I'm at the house now bike is at the barn or I'd look) the instructions say these go to the stator plate. Is this from my pig tail coming off my motor or do these connect to my magnet pick up. I suck at wiring just FYI. The pic is before I installed bb
Share This Page
