1. Dismiss Notice
    Dismiss Notice
New member, first XS!
Discussion in 'The Garage' started by B_Crabaugh, Jan 2, 2019.
  1. B_Crabaugh
    B_Crabaugh XS650 Addict
    Hi all,
    I have been reading a TON of threads over the last few weeks and decided to pull the trigger on a 1980 XS650. Amazing how much great info is on here! I got a great deal on the bike from Cycle Heap in Portland, OR
    The PO sold the bike to them because he couldn’t get a spark. When I stared the tear down today, I seemed to have found the problem. There is a Boyer Bransden advance unit, but no red or blue box! Interestingly, the stock TCI ignition is there, but no stator pickup! The bike also has what I believe is a Mikes high output dual coil. I’ll verify that when I get a new multimeter (mine broke today!). Anywho, I guess it’s time to decide if I want to source the TCI pickup or the Bransden unit. Thoughts???
    E86AF570-F428-4A97-8B14-86E30AFA18AA.jpeg 341C8FFD-3FED-4821-8B54-2B875357DE51.jpeg
    Wulfbyte, gggGary and Mailman like this.
  2. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    Welcome to the forum!
    B_Crabaugh likes this.
  3. Machine
    Machine Race the wind Top Contributor
    Fun shop to visit and support !
    Nice to have a new Pacific Northwest member as well.
    I think you can source your stock 80' ignition components locally by asking around.
    -RT
    Wulfbyte, peanut, gggGary and 3 others like this.
  4. fredintoon
    Hi B_Crabaugh and welcome.
    That alternator looks like it's had a hard life, eh?
    Check the dreaded PO didn't swap in the '79 or earlier alternator that didn't have the
    ignition trigger pickups on the stator or the pickup trigger magnet on the rotor.
    What I'd do is get the Boyer's missing parts and see if the bike will run once there's sparks.
    Then you can see if the alternator will actually charge. If yes, good enough for now.
    If no, check the list's want ads for a working late model rotor & stator to restore the stock ignition.
    This leaves you with a complete Boyer ignition system as a standby or as a saleable asset.
    Then, check the tires age stamps, swap the dork bars for bars with better ergonomics,
    swap the front brake lever with one with half the piston area and do a test ride.
    Wulfbyte, Mailman and peanut like this.
  5. B_Crabaugh
    Haha. It looks like the OG alternator. If I can find an affordable Boyer box, I will run that. If not, I'll get a TCI pickup. New tires have been ordered (Shinko 270's), probably adding reverse clubman bars, and swapping the MC for an 11mm TR250.
    Wulfbyte and gggGary like this.
  6. Superjet
    Superjet XS650 Junkie Top Contributor
    I have the shinko 270's front and back 20181230_145710.jpg and love them! 20180814_210706.jpg
  7. B_Crabaugh
    Wulfbyte likes this.
  8. Superjet
    Thanks! Been working on it once in a while for a year now. Very close to being done, but are we all really done?!?!
    Brassneck, Wulfbyte and B_Crabaugh like this.
  9. Superjet
    I run about 28 psi in front and 30psi in the rear. Too much will make the tire peak in the center and upon leaning the bike would create a very awkward feeling as if the bike would lean on its own. I got the tires mounted from a dealer ($25 per tire with rims off the bike) and the put way too much air in it.
  10. Beags64
    Beags64 XS650 Junkie Top Contributor
    569
    1,778
    143
    Michigan
    Done? If you're done ya got nothing to do, start gettin' bored, "Well maybe if I...", that's when the REAL trouble begins!
    Superjet and azman857 like this.
  11. Superjet
    I know. I have a brembo front caliper kit to frig around with and fab up a bracket to mount on the fork sometime. Got a few things to do on my other bike, changing all brake pads and lines to braided stainless.
  12. Beags64
    569
    1,778
    143
    Michigan
    Brembo bracket you say?
    Wulfbyte, Superjet and Mailman like this.
  13. Superjet
    Nice!!! What's that rotor from? I like it.
  14. B_Crabaugh
    Here is how the bike sits as of today. Got the carbs out (what a pain!), battery box, rear fender, seat, turn signals, etc. 35DC4B1F-BCCE-4F3E-A965-FE73D71BA23B.jpeg Shall I start a separate build thread?
    Mailman likes this.
  15. Beags64
    569
    1,778
    143
    Michigan
    Sorry for the hijack...
    Ducati rotor, same bolt pattern & hub dia. "Bout a 13mm spacer, on a '77 spoked wheel, not sure what size spacer would be needed for a mag wheel. Still need to get wheel laced up to figure out how much I'm going to have to "clearance" off the back of caliper.
    Superjet likes this.
Share This Page
