1. Dismiss Notice
    Dismiss Notice
Newbie from Tucson, AZ
Discussion in 'The Garage' started by plane_ben, Sep 18, 2009.
Tags:
  1. plane_ben
    plane_ben XS650 Junkie
    Thanks for the links Travis. Really cool stuff. I downloaded all the plans and will get it printed at Kinkos.
  2. Travis
    Travis Staff Member XS650.com Supporter
    Yeah I can't wait to see what you come up with. I'd like to build a girder someday. Are you going with a traditional look or something a little more modern?
  3. plane_ben
    Just got back from Kinkos. I just got the GF prints made, as I didn't have cash enough for 8 copies. Will ge the SY prints later.
    I think I will be going with a vintage look because I'm doing a hard tail. I have several ideas,so I'll do some mock-ups and see what I like best.
  4. plane_ben
    Finished putting my engine back together. All polished up with a new Pamco electronic ignition, and TC Brothers Choppers carb stubbs.
    [​IMG]
    [​IMG]
    [​IMG]
  5. Travis
    Looks good!!! What did you paint the cylinders with? Is that a new stator?
    You going to put Mikuni VMs on the those carb holders?
  6. plane_ben
    Yes, a new stator from mikesxs. Forgot about that. Didn't have one when I bought it. The cylinders are painted with barbaque black. Haven't yet deceided on carbs. Likely some mikunis
  7. Yamaha_chop
    Yamaha_chop Fabricator Extraordinare
    Great looking transporter man! What's powering that thing?
    My father and I are finishing up a 14 year restoration of a '66 21 window deluxe microbus. Should be awesome when finished.
    Engine looks great too, I need to get mine that clean.
  8. plane_ben
    The engine is a 1955cc Stroker, with 74mm crank, and 90.5mm pistons and jugs.
  9. plane_ben
    Made some progress in the last few weeks. The hardtail is welded on now. I also picked up some cool spoke rims. They're off of some Kawisaki criuser. A 16" rear and a 19" front. I'll post some pics of them tomarrow.
    [​IMG]
  10. Travis
    Looks good! Lots of people using the TC bros hardtails. I bet they're staying busy.
    Did you put the engine back in or use an engine jig when you welded that up?
  11. plane_ben
    Yes, I used the engine, and a piece of exhaust pipe 8 1/2" clamped between the axle.
  12. Travis
    That's cool. I helped a friend with a TC bros hardtail install and even with using the engine, it still didn't line up that well when putting the engine back it later. We were working pretty fast and there were a few of us so I don't know how tight the motor mounts where and if they were all in. Next time I do it, I'm going to use an engine jig.
    I was wondering what that was between the axle plates. Kind of hard to tell because it's so shiny!
  13. crash
    crash XS650 Junkie
    nice job on the frame ,keep us posted onthe build
  14. plane_ben
    Will do! These forums are what keep me motivated. Can't let the viewers down.:D Seriously, I do keep motivated with this and other forums. I like the feedback and ideas that come from seeing others build their bikes.
  15. Travis
    And you pretty much promised me a homemade girder! :D haha.. So I'm looking forward to that!
  16. shreveport1
    shreveport1 XS650 Addict
    WOW!! you got the engine looking really good now!! I used a Mothers powerball to bring mine back to life....what did you use??
  17. plane_ben
    I sanded all the parts to be polished with 320 grit wet or dry paper, then used a polishing wheel first with brown ruge, and finished with white ruge.
    Travis, the girder is in the works. I've machined the top triple clamp to clean off the fork leg brackets and squared every thing up. It's at the welders now getting a 1" diameter alumium bar/with 5/8" hole bored through it welded to the top triple clamp. I will run a shaft through that hole and anchor it with some decreative bolts. That will be the pivot shaft for the top doglegs. I'm thinking I will do the bottom triple the same way. I may have to add some material to get the off set right, so I'm waiting until mock up time to figure out final demensions.
  18. Travis
    Man you work fast! If I had that kind of ambition, I'd actually get stuff done! Can't wait to see what you come up with! :D
  19. Mellowyellow
    Mellowyellow XS650 Addict
    Wait Wait Wait,
    well you are building your girder make 2 of everything and send some of that iron my way hahaha, im really looking forward to your results.
    Judging by some of your other work this is going to be ART.
Share This Page
