plane_ben
XS650 Junkie
Been doing some mock up on the rear rim for the Yamaha. Bought some Kawasaki rims for it awhile back. They were about an 1 1/4" to wide, so I made a few adjustments so they would fit the Yamaha spacing.
You can see the milling I did on the hub between hub and sproket.
This pic shows the brake backing plate still on the mill. I'm milling down to the blue line.
These two show the rim mounted. May still need to narrow the sproket side bearing seal area, as it is pretty close to the axle adjuster. I need to weld spacer washers on the inside of the adjusters so they fit the width of the 3/8" adjuster plates on the frame
