Wanted to try it a few weeks ago, borrowed a set of stock pipes. However I revised the passenger footpegs years ago, they don't quite bolt up anymore...
I'll see if I can fab up temporary heat shield.
Regarding carbs in general: my other bike is FI and always runs perfect. What should I expect from these older bikes with (semi modern) carbs anyway? Can you even have one setting, all year round, idling always stable at 1200. Or does one need to adjust the idle adjuster every now and then? Just trying to manage my expectations here so I don't chase my tail.
If FI is fuel injection that is an entirely different setup with other possibilities
On a Fireblade I have there is a vax plug that regulates idle
and electronically controlled ignition with a lot of sensors that affects ...it has variable intake and exhaust lengths
above 8000 rpm it opens
I don't believe it is possible to get a even spot on idle on an XS 650 i have never had it
It depends on outdoor temperature and engine temperature. and so on
Yesterday I was out opening up 5 -6000 rpm down shifting while overtaking
140 Km / h a short while
outdoors ca 10 -13 Celsius
At home put it on the central stand to listen after mechanical rattle Idle close to 2000 rpm
At other times it is 1300 - 1500 at upstart
Dont stall which has happened that also over the years ..
The carburetor is serviced 2 years ago in a rebuild
With 2 step up pilot and one Main don't remember needle position.
That is probably a bit to much but it starts and above all No vibrations at all NOTHING
at cruising speeds.
I admit I am no Carburetor guru or so but this is a setup that works for me and the little extra fuel .Makes me sleep better not running lean.
Judging by your video in # 964 that is as good as it gets in my view there is a " Rough " sound very slight like pinging but it is difficult to asses on this video Can be something else ... Bearing play a loose washer
I don't think it can get much better at idle I would focus on how it behaves on the road throttle response ( It appears good on the video not perfect but good ) and
Foremost keep an eye not running lean .. I have had a worse idling for 35 years than that ..
Many years with a worn advance unit not being able to let go of the throttle at all.
