1. Dismiss Notice
    Dismiss Notice
Nissin 14 Front Master Cylinder (1980)
Discussion in 'The Garage' started by koyuga, Jul 2, 2018.
  1. koyuga
    koyuga XS650 Enthusiast
    Did I see somewhere that you can remove the plastic reservoir from this Master cylinder.
    I wanted to strip it and paint for a rebuild.
    Secondly the reservoir is discolored. Can it be cleaned up??
    thx
  2. angus67
    angus67 Welder's penetrate deeper!!
    When you have the four screws out, grip it tightly and turn it either direction 90 degrees. But, no one has found a good source for the large oring that seals it together. You may be lucky and the oring will be fine. Mine was. Others not lucky.
  3. koyuga
    thx.
    yeah tried that but seems very tight and stuck on.
    does turn but quite firm.
    will keep at it .
    cheers
  4. toomuchstuff
    toomuchstuff XS650 Member
    If you do need a replacement o-ring, it is a standard JIS size. I just measured it up and ordered a package from an online o-ring supplier. If you need the size, let me know and I'll look tonight when I get home.
  5. 5twins
    19,996
    11,878
    813
    robinc likes this.
  6. DogBunny
    DogBunny Motorcychologist Top Contributor
    robinc likes this.
  7. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    That o-ring gets gunk BEHIND it just like the caliper seals. Twist a bit and get the plastic slightly separated from the metal, I'll use a putty knife to help if I have to, and dribble some brake fluid in the crack, a few more twists and it comes right out.
    robinc likes this.
  8. DogBunny
    Yeah, to add to what gggGary just said, once you get the reservoir off you'll understand why it was so hard. The plastic reservoir is sort of like a bayonet/mushroom-head push-fit into the M/C body. I also use a putty knife -- a thick, stiff one with about zero flex -- and a LOT of force. I may have to start with a thin putty knife, and then go up to the stiff one. Be bold, you aren't going to damage anything.
    lakeview, robinc and gggGary like this.
  9. koyuga
    Great. Thx
    To all
    robinc likes this.
Share This Page
