SpongeBobbed
650 Simpleton
Hi There,
1980 special that I've changed up a bit to look more like a quasi cafe.
It was leaking like crazy so I took everything apart to put in new seals and gaskets and while I was at it I put in some new parts (brass swingarm bushings, new sprockets, wheel bearings, fenders, etc.) and I did some painting (mags, calipers, light housing, forks, etc.).
Anyways, I put everything back together and when I turned the key I got nothing.
Here's all the info I have that I think could help find the solution:
- put a new battery in. Just a normal 12v from Canadian Tire. Trickle charged it last night and when I tested it in the bike I got 12.6 v.
- I was getting power before I took the bike apart
- the only electrical components I messed with was the alternator when I removed it to change the main oil seal. I put it back exactly how
I had taken it apart and followed the video that is posted in the tech section.
- I powder coated the front forks, and the rear fender (got a new black front fender from
Mikes)
- I plasti-dipped the light housing, housing tabs that come off the forks and the top of the forks (between the triple trees). I hate the stuff but wanted to black out that little bit for now until I take it apart this winter for proper powder coat.
- fuses look good and I didn't change any connections except for the neutral light connection near the cam chain housing.
Does anyone have any thoughts??
I know there is a bunch of threads on this but I thought someone might see this and have a brilliant solution as to what the hell I screw up.
Thanks!!
Mikes)
Thanks!!
