Port
I'm not getting spark on my 1981 XS650 heritage special. I replaced the wiring harness and plug boots. cleaned almost all of the connections coming from components to the harness and cleaned the kill switch and ignition switch contact points. The coil tests good but the case has some cracks in it, I'm thinking I'm going to replace it but I haven't decided for sure yet. The harness came with glass fuses that i'm going to replace at some point but, seeing as how they are brand new and aren't causing voltage drops across the fuses I don't see theme as a probe at the moment. That leaves me with the TCI box as the problem, as far as i can tell.
Pictures of TCI Unit: http://imgur.com/a/FM784
I think I may have found the culprit but I'm not positive. Note the red-ish colored component next to the 2 resistors. It looks like it has suffered some damage from overheating. I'm not sure what the component is, how to find out what it is, or how to test it to see if it is indeed fried.
I've also read that the 4 diodes just past those same 2 resistors are known to be troublesome. I've read some places that you can test them in place and have also read that you can not test them in place. If i can test them, how do i do so?
The solder points look pretty good for circuit board that has been strapped the the bottom of a bike for 33 years.
Lastly, i haven't been able to figure out how the handlebar controls are grounded to clean the contact points or how to check them for ground.
Any advice is welcome
