Hello Paul
I agree. It just doesn't look quite right and the front wheel was a devil to get in place. I suspected the the front forks may have been bent but I wasn't into a fork rebuild then as I had so much on my plate. I figure I'll loosen the bottom clamps, the axle, the fender mounts and the calliper bolts and give the whole front end a good "bouncing" with both wheels straight and on the ground and the bike held upright by some volunteers. If necessary, I'll put the wheel between my knees and twist it little to finish the job. The trouble with rebuilding the whole bike is that you have to be good and so many different jobs - I may have short cut on the front end alignment.
If that doesn't cure it, I'll rebuild the forks with new tubes from TC Bros and check my steering bearings at the same time, but not just yet. Plan on riding her a little first. She's running OK on the road without any noticeable issue apart from an occasional clunk which I suspect to be bearings.
