so ive been having some white smoke issues with the recent 750 kit that i put in. at first i thought it might be due to the valve guides since that was the only thing that wasnt changed.
BUT
i did a compression test and both cylinders are reading around 110 lbs/sq. in. is this normal? Im pretty sure the cam has more duration right? which cuts down on compression. what should the compression reading be for a new 750 kit with a cam.
also the white blue smoke use to go away after warm up but now it doesnt... could this mean that the new rings and cylinders are causing the smoke??? I know i installed the gaps in the rings 60 degrees apart from one and other.
BUT
