Guys, I'm pretty sure I know the answer to this, but, if there's any alternative I'd really appreciate any help:
Just about finished my XS hardtail dry build, very early on in the build I acquired an engine, po said it ran well, but you can never trust that. Anyway, I did a top end rebuild, noting that the LH cylinder (LH as you sit on the bike) did contain lots more carbon than the right, also the exhaust port was quite badly fouled. I put this down to worn stem seals and naturally replaced the lot during the rebuild, however, I did notice a bit of movement in the exhaust valve, but didn't measure it. At the time I phoned my local cylinder head specialist for a price to put in a new guide - he never got back to me and for various reasons I didn't chase him - just put the engine back together.
Build also included checking the ring gaps, which were fine and a very, very light hone of the cylinders.
I've had the engine running for a total of about 30 mins I suppose and noticed the LH cylinder is definately still burning oil. Stripped the bike today, ready for paint and when I removed the exhaust, I literally got a small dribble of oil out of the exhaust port. There's quite a bit of oil getting in there, but it doesn't seem to be getting in the combustion chamber as the piston looks as clean as when i fitted it, also the plug is quite clean and the RH port is bone dry.
Below is a pic of the port, I've already wiped most of the really wet oil out of it:
I've also included a picture of both plugs, although I don't know how much the colour of these can be relied on as the carbs haven't been set up and the RH cylinder isn't firing properly - LH plug on right
So, my best guess is that the guide is completely shot, I would also guess that a new valve is needed - does anyone have any other ideas?
