Wondering if anyone else has had oil leak when the engine is hot from what appears to be the bolt just in front of the dip stick? Thought maybe it was coming from the dip stick, so I put a new rubber seal on it because the old one looked worn out, but that didn't fix it, and the oil seems to be coming from the bolt with the #6 on it. Tried tightening it up to no avail, and even took it out and used gasket sealer around it but still leaking. Just wondering if anyone else has experienced this and what they did to fix it. It's an 81 special. Thanks
