1974jh5
Curmudgeon.
I want a better front brake but at this point don't want to get into hanging a 4 piston caliper and different rotor on my bike(although that could happen in the future). I decided to use an 11mm master cylinder on my 1980 XS650 with a single 38mm caliper, which seems to be a common swap. Got one from Mike's, it bled out perfectly (I've bled plenty of bike brakes before, this was no different) but the front brakes were nearly nonexistent. I realize there will be an increase in lever travel but it goes all the way to the bars and it's unpossible to lock the front wheel. I thought it was the lack of a slack adjuster, so I drilled and tapped for an adjuster screw, still the same problem. The caliper piston moves normally, the caliper and pad slides are clean, the hoses are stock but are in good shape.
A 11mm master cylinder is a 3mm drop in bore size and that's a HUGE drop, like 21.4%. A 12.9mm bore cylinder is a difference of 1.1mm, which is a 7.8% drop in bore size. I'm thinking that's where the problem is, but before blowing another $80 on a 12.9mm master cylinder I wanted to pick the collective brain here.
Others on this board have done this swap with good results. So where did I screw up?
