Mentioned to Jim that he must have arms like Superman to wrestle that cam chain on there. I knew this was going to be the toughest part of the job.
Wasn't wrong.
Put some more pex spacers on the studs, tightened the head down somewhat. That helped a bit, still a little ways away.
Buddy then said why don't we do it the way we took it off? Good idea buddy!
We had removed the cam with the chain intact by pulling a pair of bearings off.
Did that again. Pulled the left side bearings, which dropped the cam enough to get the master link on the chain.
Slid both bearings over a #3 JIS screwdriver. Insert into cam, lift and very lightly tap bearings into place until the inner bearing was seated.
Then added a large socket to seat the outer bearing. Whew!
In hindsight could have done a couple of things better. Should have used sockets instead of the Pex, less squish.
And should have added a little more preload on the studs which would have allowed us to get the chain on without pulling the bearings.
Ah well, in the heat of a high anxiety moment we did figure a way to get it done.
Jim’s link riveter has a nice rounded pin end. On these cheapies, the end of the pin is flat so it tends to slip off the rivet. I filed the tip so it inserted into the link better.
The first one had been bent while trying to remove the old master link. It bent here again beyond serviceability.
I had added that replacement pin to a XS650Direct order for this job.
So filed the second, it bent, then broke. I probably rounded it too much so that it seated too far.
Ended up finishing it as per Hans Pahl, with buddy holding a big back up hammer while I used a big centre punch and hammer.
Just one example of how having 4 hands makes this whole job easier. I don’t know how you guys do it solo.
I guess with time and experience you must develop your bag of tricks.
Wanted to run this next one by you guys.
I had read a post awhile back by Aldo5468 that he had used these valve adjusters.
He did say that they were shorter but that there was enough thread.
Here’s how they look installed.
Not much extra exposed thread there.
Would you guys be comfortable with these?
Gotta say it sure is easier adjusting the valves with a ‘T’ handle allen key.
We're getting closer!
