1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
One Turn Signal not working 1980
Discussion in 'The Garage' started by Andrew Burt, Mar 9, 2018.
Tags:
  1. Andrew Burt
    Andrew Burt XS650 Special 2
    5
    2
    3
    Houston
    Riding the other day I went to turn on the left turn signal and saw that the front left signal had broken off and was hanging by the wire. Also neither the front or the rear would left turn signal would light up. The screw had broken in the middle.
    I ordered a replacement turnsignal on ebay. Took the headlight off, cut the wires and put in the new one. I was hoping this would solve the issue, but neither the front or the rear will still light up on just the left hand size.
    Is there any suggestions what to trouble shoot next. I fgured it would be a fuse or something simple that blew when the wire got tugged, when the signal broke off at the screw, but I couldn't find anything.
  2. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    Welcome to the site.
    When the wire tugged, it may have loosened up one of the other connections in the headlight bucket, like one of the ground connections (black). Check the integrity of all the connections in there.
    Paul Sutton likes this.
  3. 5twins
    21,930
    15,493
    813
    Make sure you have the right wires connected to the right places. The dark brown and dark green wires for the turn signals can be easily mistaken for black ones if dirty. Also check/test both left side bulbs. If you still have the stock flasher unit, it is very dependent on having 4 bulbs of the proper wattage. Vary too much from those stock values and the unit won't flash.
  4. yamageddon
    yamageddon XS650 Addict
    Try troubleshooting by changing the cabling for 'left' and 'right' in the headlight. See what that does?
    Andrew Burt and Paul Sutton like this.
  5. Paul Sutton
    Paul Sutton I Collect Fingers XS650.com Supporter Top Contributor
    Andrew Burt and yamageddon like this.
  6. Andrew Burt
    5
    2
    3
    Houston
    Ok, Thanks for the help, it gave me some great ideas of what to try. I tried plugging in the left lights into the right connectors, and they ignighted propertly. Then tried the right in the left with no luck. So I now knew it wasn't the actual indicators. I followed the wires to the turn signal horn switches. I went to remove that and the indicators started working, so I knew it was something loose in there. I went the rest of the way in taking the rest apart. It appears that the soder joint had come loose at the little switch within. Unfortunately I don't think there is even the slightest chance of me fixing it while it is still on the bike. I'm going to go ahead and order a replacement set of switches, after I put the new one on I'll try and resoder everything so it works properly.
    yamageddon and Paul Sutton like this.
Share This Page
