1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Paint Project
Discussion in 'The Garage' started by TimG, Jul 16, 2019.
  1. TimG
    TimG XS650 Enthusiast
    I airbrushed the platinum metallic stripe last night.
  2. MaxPete
    MaxPete Life with Lucille...I suggest, she decides. Top Contributor XS650.com Supporter
  3. Wordman
    Wordman XS650 Enthusiast
    Not that TimG has done anything wrong (he absolutely hasn't), but it's better to put down a coat of epoxy primer, then do body work, then high build epoxy to finish.
    MaxPete likes this.
  4. TimG
    Pete: I pulled the tape after about 15 minutes. I am using a pretty fast reducer, so the paint is flashing quickly.
    MaxPete and Wordman like this.
  5. TimG
    Sprayed clear last night. This has not been sanded or polished yet.
    59Tebo, Wordman, Bushyeyed1 and 3 others like this.
  6. Bewarethemoon
    Bewarethemoon XS650 Addict XS650.com Supporter
  7. TimG
    Thanks Daniel. Looking forward to posting the finished bike pictures soon. I have a new halogen headlight, new grips, a tach block off cap, new rubber mounts for the tank, new fuel lines and new barbed carb boots to install and then I am going to need to find something else to do with my time!
    Bewarethemoon and MaxPete like this.
  8. MaxPete
    Beautiful job Tim - that is very smart indeed!
  9. Bushyeyed1
    Bushyeyed1 XS650 Addict XS650.com Supporter
    Looks really good thanks for sharing.
  10. Wordman
    How long between base and clear? Most base coats need to be top coated within 24 hours (or less), what's the specs on yours? What product are you using?
  11. TimG
    7 days per the PD sheet. I was right at the end of the window with stripes and life getting in the way. I color sanded prior to top coat so I am not worried about adhesion. Otherwise I could have sprayed an inter-coat clear to and then striped over that which would have extended the window. My base is Martin Senour PRO Base and I am using the FC720 Ultimate Clear.
  12. Bewarethemoon
    I’m looking forward to seeing them!
    Daniel.
  13. Wordman
    Thanks!
Share This Page
