"I just switched from a points XS650 ignition to a basic system Pamco electronic ignition with E-advancer & ignition coil kit.
After installing this, the bike starts good. However, the starting point indicated in your instructions did NOT work to set the sensor plate,
but the old recommended setting seemed to work.
I understand that a timing light is also needed. Do you have any advice? Thanks..."
