NorazDad
NorazDad
Hey Guys,
I have read every thread on this topic. I know advance from retard. I have installed an HHB PMA, Pamco with EAdv, shaft, bushings and the replacement rotor for the right side of the cam. I believe the pin was inserted in the right place at the top of the shaft rotation. I have adjusted the Pamco plate in the correct position and attempted to time with a timing light. It is not jumping around. I have a great visual on the mark I made during the HHB PMA install. I know it is not dead accurate by degree, but when I shine the light on the rotor with and engine that is at 1200rpm and no smoke from the pipes and no coughing and kicking, the mark is way past the advance mark.
I have tried to adjust the idle as I tried to move the plate to move the mark and all I get is sputtering, choking and smoke out of the carbs upon engine shut down.
There seems no way to move that timing mark toward the retard and into the fire zone.
I don't think it is the cam chain. The light is not jumping around.
Last time I tried to time this, there was so much smoke coming from the pipes that I changed the valve stem seals. That's another story, but thanks Farrell. After that job I took two rides of about 25 mi each. Wasn't running quite right so I think it's all about balancing carbs and timing. But timing seems to be the biggest issue. If everything is too advanced, what do I need to do to bring it back in?
I am so close and I love that I can start my kick only bike with one lackluster kick.
But the timing light tells a very frustrating story.
I am pleading for some assistance here. Remove the Pamco and reinstall> I've been waiting to locktite nuts.
Is there some method of perceiving correct timing by getting in tune with the bike?
Thanks All.
Thanks All.
