On the points bikes they had a range for idle timing because they used two sets of points and it wasn't easy to get then both timed to one mark, thus a range. That way as long as you could get both sets of points within the range it ran ok. They do run better the closer you got them.
On the TCI bikes it only had one coil firing both cylinders so it only needed one mark.
Also the points bikes had a full advance mark so you could tell if the advancer was getting worn. As it wears the advance changes.
On the TCI the advance was controlled by the TCI not mechanically, so no wear.
