Pamco to a Dyna DC3 mini coil
Doc676
Wookie
Westfield, IN
I have a rephased (thx Hugh) now an XS750, with the Pamco electronics for the rephasing. I'm not using the green monster coils due to space limits. I'm using a Dyna DC3 mini coil, (dual output, dual fire; couldn't find a dual output single fire when I bought it). I know someone has done the wiring for this but I can't seem to find the thread. Also need help finding a simplified wire diagram. I'm using kick only with a small battery, headlight, tail lights, brake, kill switch and possibly a RF ignition with FOB, no key. Any guidance is greatly appreciated. If you can't tell I hate wiring.
Doc
I run one of those dyna coils. They are great. So compact. I think this is basically the wiring layout you want although i don't know if the re-phase makes any difference. There is a tech section on wiring with pretty much every wiring schematic you could imagine.
Doc676, did this setup work out for you? I'm wanting to avoid the two monster coils as well. Would like to know how it worked out. Thanks!
