firedog
FIREDOG
Just installed the E Ignition on my 75 xs650
All went well, started right up set the timing. Rode a mile and the bike died
Restarted and will run for a min and shuts off.
Running stock charging system with electronic regulator/rectifier.
New Battery.
Have 12V + on coil and Pampco
Have good ground, dito
Green wire has good conection to coil
Checking with the cam pin removed and a spark tester I have great spark for about 20 revolution.
After turning ignition off for 1 min I can repeat the cycle.
I'm not an electronic expert but it appears something has a bad connection weak solder joint perhaps
Pampco Pete help please!
New Battery.
