For Sale - Parts leftover from 1974 TX650A bobber build
mattgiblin
Colorado Springs, CO
All parts off 1974 Yamaha TX650A
Swing Arm and Swing Arm bolt with crown nut – $35
Clutch Push Lever with all hardware and return spring (plastic assembly broken but there)- $12
Driver foot pegs - $20 for the pair (under scrape on one side, comes with bolt on framing and acorn nuts
seen here. I have cut some of the original foot peg mounts seen here but it could easily be welded back
together)
Passenger foot pegs - $20 for the pair. (one cut made to the rear bolt on mounts)
Drive Sprocket - $5 – one tooth worn down
Original intake manifold with chrome rings - $10 for the pair
Mikes XS air filters - $10 for the pair (fits original carbs)
Aftermarket handlebar risers – $15 for the pair - fits 7/8” bars and fits with original bike handlebar
clamps
Right and left side engine case bolts - $5 total
OEM headlight socket wiring - $5
Chain with master link – fits original - $10
Rear Brake linkage rod - $5
Battery ground cord (yes it is red) - $2
All total - $154 – take it all or buy pieces. You pay shipping.
Let me know if you need additional pics/ dimensions, etc. The two pics are the same parts flipped over or on the side.
