These may be them, see post #27. I haven't tried them yet but maybe some day .....
http://www.xs650.com/threads/rebuilt-carbs-overflowing-random.15344/page-2
So you think just the seat and needle valve with a new bowl gasket and call it done?
I had a very similar carb on my old 78 IT400. It was a Mikuni as well (Yamaha and Mikuni worked together as we all know. And when it leaked air found that it was the over flow tube but this set of carbs isn’t set up that way. In fact, I can’t quite recall how the overflow is set up on these. I’d be almost willing to garuntee it just needs new seat and needle valve (sorry for mistakingly calling it a needle jet...) I’d like to get my hands on an external float measuring tool. In school we used the manual slide adjusted tool, never really liked that method...Yea answers can be confusing.........One says don;t get kits, another says some parts off kits can be used, (may save money compared to buying separate parts).
Have to do some work your self and find out what is needed then an answer will reveal itself.......The old keyster Carb kits had the rep for parts not working for the yaer carb..........
With new players in the market i don't think anyone has done a proper valuation of their parts and fit-ability..........
Old information may not be relevant in today;s market.........??
That's kind of what I was thinking. I'm just glad I found the manuals for it. I'm gonna he looking into the front end more when I need to figure out the turn signal relay issue. As well as front brake light switch and other front end issues. I feel much more confident in doing work on the rig with manuals to help me though. Correct me if I'm wrong, but the manuals from the 70's have a lot more to offer than late 90's and early 2000's... The information is more in depth and doesn't leave quite as much guess work.Yamaha didn't publish full manuals for every model year. A full manual came out every couple of years and supplements were published for the in between years. Your '76 got a supplement, to used with the last earlier full manual which came out in '74. But your bike has a later front end swapped on so will require the '78 and later manual for that.
I downloaded those! They're awesome. I saw Yamaha still sells print on demand manuals for the bike but it's $90...You can download all the manuals you need/want for free from the XS Cafe web site. I suggest getting the early full one that applies to your bike along with it's specific year supplement. Also get the '78 and later manual for your front end and brake.
https://thexscafedotcom.wordpress.com/2011/01/10/xs650-manuals/
There are also parts manuals there, which can be a big help just for showing how things go together. Most of us eventually try to acquire paper copies, real books, because they're just easier to use while working on the bike. Watch eBay, reasonably priced copies pop up all the time. Most of us also agree that the factory manuals are best. The aftermarket Haynes and Clymer manuals are not as good. Here's one to watch. It would be a good one to get because it is a combination of the earlier full manual and some later year supplements .....
https://www.ebay.com/itm/Rare-1974-...=item443727ea6c:g:1pgAAOSwjF9cTHK9:rk:13:pf:0
We like the way you have charted out the options. I have been building motors for years and have seen many of sump filters and oil filters. MikesXS parts work just fine. Trust me replacing that sump filter gasket on the bike is a pain. Ensuring both the mating surfaces is critical and clean is the key. Those older gaskets are pretty tough sometimes and working upside down - no fun! Be sure to get out a small acid brush and good gel paint remover to assist in softening and removal of that old hardened gasket. The filters themselves are metal screen and cleanable. Be sure to look at the original sump filter to not have any openings around the screen attachment. If you see heavy deposits of metal or opening on the original filter, I suggest a filter exchange. MikesXS has good tech advise when it comes to any questions with the 650's. Never hesitate to contact them directly.OKAY, Long time no see, so hello everyone. Yes I still have the XS. No, I haven’t touched it this winter. (It’s been cold, and I’m sad about it) HOWEVER. I’ve been saving my money and I’m now ready for the basics to go into it. That being said, I’m looking to 1: change the oil, 2: rebuild both carbs, 3 replace the torn up clutch cable, and 5: seal this gas tank once and for all!
I am set on at least one thing: CASWELL tank sealer. Gonna go with “dragons blood red” for the color, simply for contrast to the blue on the tank and so I can see even coating inside.
Now, before I get questioned... I scribbled out part #’s because I didn’t think very hard about how to chart it all out, and realized each site had a different #...
I’m TOTALLY LOST on where I can find good sump filters and smaller oil cleaner element... been comparing prices, and finding very limited results. I’ve been told MikesXS is a last resort kind of deal... saw some posts about the quality of their oil filter gaskets being poorly cut. I’ve found gaskets for that on other sites, but I’m not trying to spend more than necessary. I’m looking for recommendations SPECIFICALLY for just the oil filters and gaskets, as well as if anyone knows of any other place I can find a full carb rebuild kit anywhere other than MikesXS... pretty much everyone has clutch cables so that’s all depending upon what handlebars I choose to replace the “buckhorns” I DID look at the tech section a bunch today trying to gain insight, but something tells me that like wine, advice gets better with time, and someone may have found a decent resource that wasn’t posted in tech recently, thanks a ton in advance for all the help guys. Hope everyone is doing well.
Yup, a Royal Pain.Trust me replacing that sump filter gasket on the bike is a pain. Ensuring both the mating surfaces is critical and clean is the key. Those older gaskets are pretty tough sometimes and working upside down
